2010 Polaris ranger 500 efi
Have 2010 ranger 500efi runs rough at idle and stalls sometimes any ideas of what it might be ?
Brad, could be>>>>>>>>>>>>>>>>>>>>>>anything. Bad plug, fuel pump, bad gas, plug wire, valves to tight, sensor wire bad, dirty air filter etc... What have you done to try to rectify ?
I just bought it it was recently in the shop for the same issues . They changed out ecu on unit. I have checked plug looks good. Only runs rough on idle. Once I bring rpm up it does smarten up. Pulled air filter tried running it no difference. Not to familiar with the rangers. I did pulled sensors on throttle body and clean. TPS I guess to can’t do nothing with as it’s a sealed unit. Kinda checked over wiring tried wiggling it around trying to get it to change while unit was running .
I did try adjusting tps just by sound not actually measuring volts. And I thought I had it as it did smarten up a great amount. Went back a few days later and ran it and it started doing it again.
