2011 Ranger 800 XP high output EFI. Driving along, temp 195 degrees and it just stops running, no warning, no backfire, just like turning off the key. Stop the Ranger, turn off the key, press the brake pedal, wait until the fuel pump builds pressure, and it starts with good power and acceleration. Might run for 5 seconds or 5 minutes and then dies again and again and again. ??????? I checked all electrical connections and none are loose. Got it on a trailer and home then started it and it unloaded under its own power. Parked it and put it in neutral and it kept running but I did notice that when I ran it above 3800 rpm in Neutral that it has a constant even miss.
ANY IDEAS ??????
ANY IDEAS ??????
