`06 Ranger 2x4:
Wanting to use my tank spray rig, and my Polaris Xplorer 4x4 came factory equipped with a protected (capped) two-wire 12V pigtail.
Anything similar exist on a Ranger? I did not spot one anywhere.
I can certainly add one from the battery, or put together a plug/cord for the lighter outlet; just hoping for a protected circuit/connector already in place.
Thanks!
Vapor Trail Tech kit to install
Floor mount gun rack to install
So much to do, damn chores get in the way of fun..
Don't know if the 06 is the same as the 07 - I have 07 700 XP and there are 2 wires under the bed - the red one is a positive off the ignition switch
I have a Fimco Sprayer for my Ranger. The cord that goes to the power outlet has a on and off switch. The best place to plug it in is in the cab, that way you can use the switch to turn the sprayer on and off. If I was to plug it in in the back of the Ranger, I wouldn't be able to use the switch as intended too.
I too have a rear sprayer and use the power outlet with a on and off toggle switch. Works great. I attached the mirror on the drivers side as so to see the spray booms at rear.
Thanks all; I'll setup a cord for the power outlet. A spray boom unit really benefits from a toggle switch, but my smaller tank unit with wand works as a demand system, so line switching isn't critical. But a toggle switch will allow me to borrow my neighbor's boom unit!
