Blake, you will probably need to pull the axle out to work on it . That happens on the 700's occasionally when the bearing race seizes on the hub 'snout'. You may need to heat it up to get it to let go . I would have a new bearing on hand before you begin as you will probably end up carefully cutting the race off the hub.
Seems like it always happens on right rear......
