21 - 21 of 21 Posts
R, 2007 700.........won't run at spec meter set to lowest setting VDC. Back probe the yellow wire and ground the black wire. Close the throttle plate (counterclockwise the 'D' screw untill the meter stops going backwards ) Then set the TPS itself to .560 base & then clockwise the 'D' screw to .670 ish flow. I am assuming your TPS is functioning properly and the throttle body is CLEAN inside.......not 15 years old... Piece of cake..
21 - 21 of 21 Posts
