1 - 20 of 162 Posts
Quick question: For those of you replacing your OEM 570 springs with OEM EV springs, are you simply replacing the coil springs or replacing the shocks AND coil springs? Thanks.
Same question for the 900xp springs.
2015 Ranger 570 mid
Just springs, shocks are the same on the ev.
Takes the sag out of your springs. Ev springs have alot higher spring rate then the standard ranger springs
I replaced the shocks and springs on mine,gained close to 3" lift ,let me know how yours turns out if you just replace springs
That's about the same as everyone else is getting, 2"-3" just replacing springs
just add springs? and no issue with axles?
Haven't heard of any axle issues,
What are the differences between an 800 mid-size and the EV springs? I am looking at upgrading springs, but not sure the route to go.
The Ev springs have a higher spring rate and are a little taller, therfore lifting the machine and being able to haul more
Yes or a link where you bought them... Thanks!
Is the ride any harsher with the EV springs?
1 - 20 of 162 Posts
