1 - 8 of 8 Posts
Hello all, new to the forum here. So, I bought a 2014 RZR 800 EPS last year and when I started to drive it this year, my front right wheel seems to be locking up I am guessing? The whole RZR starts to shake and you can hear it coming from the front right wheel. I can get it to stop shaking if I turn the wheel a certain way, but then will come back if I hit a bump or turn the wheel wrong way. Any help would be appreciated, thanks!
Hi Frostyz101.
Possible causes:
1) Bad ball joint(s)
2) Bad Hub ( wheel bearing)
3) tie rod loose
4) Bad caliper that is seizing
Note:
these are my guesses I am not a expert by any means
You need to check all of the above. If it's not one of those, the hilliard cage in the front diff' might be going bad. If it is still under warranty, I'd take it to the dealer and let them sort it out.
ditto on the hillard T&S
· Premium Member
I agree with cammanderjjones and carnivore (always the wisest choice :) ) But one other thing I would check, if you haven't already, is to make sure there isn't a rock or some other debris wedged between the rotor/hub/wheel. Probably not your issue since the wheel spins when you are in a turn, but wouldn't hurt to take a peek!
1 - 8 of 8 Posts
