I have a 2010 ranger xp800 and it has a rough idle and running rich the idle is about 1030 to 1080rpm sometimes it will drop to 980 and it has no codes. Called the dealership and they said spray the intake for leaks I tried that even though like I said it's running rich but it didnt have any intake leaks. I put new plugs and wires in. I've checked compression(145psi), checked fuel pressure (40psi), replace tbap sensor and harness, replaced and calibrated tps and checked wires from tps and tbap all the way to ecm and tested continuity for wires and have found no issues with the wires. I've also checked the tps values at the ecm while calibrating. I backed the idle adjustment screw all the way out and set base voltage to .528 and cleaned the throttle body while I was there. And used the idle adjustment screw to set it to .70. Now with the tps set to .70 volts with key in on position as soon as I start it it jumps up to .76 even with the new tps and I don't know if that's normal. There's no knocking or smoking no gas in oil and it seems to run fine and it will continue to idle but it's just annoying and would like to get it figured out. Thank you in advance for any ideas
