Greg...
Buy the cheapest multimeter you can find with a digital readout. should be able to get one for $10-$20.
Yes, if you change the tps you must reset the tps to the correct settings or else your engine will not idle/run correctly.
if you're going to buy a fuel pressure gauge and check that anyway, then after you do that, and if you still want to check your tps or replace it and adjust, let me know, I'll walk ya through adjusting it if you want...
you may find alot on the site through search to help ya along too...
just let me know if you need some help!
Adam
Adam
