hey new to forum, does anybody know why the 900 s is 75 hp where the 900 xp is 88hp? I'm pretty sure they are the same engine. My question is can a guy put the ECM from the 900xp in the 900 s and gain the extra horsepower?
thanks for any input
The 88 HP versions were about as quick as the 1000s due to the weight difference so Polaris "fixed" it. My 2012 900 will go 78 mph stock and a 1000 is speed limited to 73 mph.
I believe the ECU plug is different between them and cannot be switched. There are companies out there that will reprogram your ECU but it's fairly pricey. I believe it's $6-700....
Vendor
The only 1000 that is limited to 73 is the 2015 four seat, the rest are not but rev limited at 8700 and most run 80
There are lots of different parts in the 88 hp motor. I looked the numbers up when the 900 Ranger was introduced. I don't remember all the differences.
The 75 hp motor is the same as the Ranger motor, we all know that.
If you want a RZR s with 88hp you could always buy a 1000 s and have 100 (bonus 12). :).
