RZR Anti-Theft Shift Lock for 2015 RZR 900 and 2014-2015 XP1K
1177 Views 0 Replies 1 Participant Last post by  Ran
Extreme Metal Products
Description
RZR "Anti-Theft" Shift Lock for 2015 RZR 900 and XP1K
·Fits: 2015 RZR 900, 2015 RZR 900-4, 2014-2014 XP1K, 2014-2015 XP1K-4
If you have an older model RZR see our P/N: 10680.
·Powder coated texture black for superior protection.
·Allows you to lock your RZR in the parked position.
·Lock is easily visible to keep thieves away.
·Easily accepts any padlock you would like to use.
·Includes: Mounting hardware.
Stop your RZR from being stolen with the EMP "Anti-Theft" Shift lock. Now, you can lock your RZR into park with the padlock of your choice. Made from Stainless Steel and AISI 1040/1050 Steel, and hardened by heat treating to make it very strong. You can bolt the bracket under your shifter housing, and when you put the lock through the part, the housing can not be removed. This is a great way to secure your RZR outside your hotel or other areas.
Why steal yours when others are easier?
NOTE: You will have to trim your rubber shift boot as pictured. Not to worry. This an inexpensive part to replace if you ever take this off (Polaris P/N 5414651).
PADLOCK NOT INCLUDED. You will have to use a padlock with a short hoop.
Click below for more info.
MSRP: $66.99
Dealer:
1 @ $41.00
5 @ $36.00
15 @ $30.57
4 lbs. UPS
