I knew it was a spelling correction thing as soon as I read your post. I send crazy stuff all the time because of it.Sometimes I think I should read my posts before I hit reply. Crazy right?
Blessing or curseI knew it was a spelling correction thing as soon as I read your post. I send crazy stuff all the time because of it.
I read all of the suggestions and all are valid, but I didn't see where anyone suggested jacking up the end of the vehicle you are lubricating to take the weight off the bushings to allow some slack. It works more often than not.I just installed SATV a arms and can’t get them to take grease. I have removed the zerk and it will pass grease through it but not when installed.
I have read a thread in the General forum with the same problem and their solution was a longer zerk. I don’t seem to have trouble locking on the zerk but who knows.
anyone have similar issues?
Why would it work?I read all of the suggestions and all are valid, but I didn't see where anyone suggested jacking up the end of the vehicle you are lubricating to take the weight off the bushings to allow some slack. It works more often than not.
I tried many different things and so far nothing has worked. I jacked it up and had someone pump grease while I used another jack and moved the a arm up and down, no joy.I read all of the suggestions and all are valid, but I didn't see where anyone suggested jacking up the end of the vehicle you are lubricating to take the weight off the bushings to allow some slack. It works more often than not.
I don’t know what else to think. I’ve backed them off and even “bushed them” with fibre washers. Some took grease others did not. The long uppers are the big problem.Are you absolutely sure the zerk isn't bottoming out on the pivot tube? I feel like I could probably force some grease in those GP bushings, but I didn't want to put that much pressure on the seals.
