I had long been looking for a set of reasonably cheap upgraded shocks for the crew. I knew the Polaris stock stuff wasn't great and I knew how much a decent set of shocks helps a sled, so i figured it would be a significant upgrade for my Ranger. Unfortunately our options are pretty damn limited. I came across a set or shocks from SATV that seems to work pretty well for my application. It was some left over stuff AK 900XP Crew LE had from his suspension upgrade attempts. I ended up with a set of Phantom reservoir shocks from SATV. The rears are what they sell to go with their Wicked 6 lift kit. The front are their RZR S shocks. I put 275 lb/in springs on the front and rear. Both sets of shocks are about 1" longer than the stock shocks, so I ditched my 2" HL bracket lift because I didn't want to push the suspension much past the limits of what the stock components allow. The added shock length translates into a lift that nearly matches what I had with the HL 2" lift and with a longer shaft on the shock, I get more suspension travel. The ride is SIGNIFICANTLY upgraded from the stock Polaris shocks. Just a little feedback on some success I had putting some shocks together for my Ranger.
