1 - 3 of 3 Posts
I am just about done with my tlc cart. I have a flat area between 4400-4600'rpm. It takes off fine to 4400 rpm then bogs a little after that then zooms right up to like 5500'rpm. Plugs new, oil new, air filter cleaned, neutral idle 1050-1090, any thoughts? Thanks
Moderator
BB, Could be dirty TB/Map probe or a chaffed /broken wire on the sensor. Not that it will always throw a EFI code, I would check...
1 - 3 of 3 Posts
