Not to be a smart ass but is your seatbelt fastened?
You may know or not know but if the seatbelt isn't hooked in the machine will limit itself to about 15mph or so.
Just starting with the obvious first.
Reactions: Jungleman
2015 Polaris ranger 570 XP
If the engine is running good I think I'd take a look at the clutch and belt. It may not be shifting properly and problems may not be apparent by a simple inspection of the outside of the clutch. There may be an internal problem with either the primary or secondary clutch.
and>>>>>>>>>>>>>>>>>>>>>check the fuel pressure ----- 58psi
