Vendor
My 2019 Crew XP 1000 Back Country Edition has been on my lift for two months, I am so slow at getting work done, just no time. But finally able to drive it with the 34" tires and portals and our HW belt on it.
I had my stock clutch fixed with the service bulletin, I aligned it myself and then installed the HW belt for it which is thicker than stock.
All I can say it is crazy smooth, engagement is just above idle, no jerking, drove it between 0-1 mph in low smooth as silk.
Of course my concern is how long will this new bearing last, but for now I can't image it any better than it is with anything.
I did put the lock out shim from Gilomen in it as a preventive measurement on the EBS mechanism from getting hung up in the out position.
here is a pic of the machine as is, yes clutch cover still off. They stay off my machines until I need them
Damn, that looks nice with those 34's and other upgrades. I'm still breaking in my Backcountry I just bought last week. I keep reading about these clutch alignment and shifting
issues with 2019 xp 1000s. So far I have noticed I need to put a little extra force to get the H gear to engage. The other gears seem fine. Was that the same issue you had? And is that what the bulletin is referring too?
HW
When do you decide you need the clutch cover back on it?
