The connectors inside the spark plug boot are not supposed to stay on the spark plug when you remove the boot from the plug right? This is the second set of wires that do that and they're less than a year old. It still runs like nothing's wrong.
Moderator
Stan, are you greasing with di-electric grease or other before install ? Sounds like you are getting some corrosion .
Yes I'm using proper grease.
Stan, you're not doing anything wrong. The plug wires used on the 800s have too much "grip" on the tip of the plug. Dielectric will not help. I see this all of the time and have no solution.
