1 - 14 of 14 Posts
Installed polaris lock n ride sport roof amd it is rattling in the front from vibration at certain speeds. The roof came with screws to attach it though they appeared optional or perhaps necessary if you trailer, which i do t but no instructions on where or how to install the screws. Im wondering if they are needed to stop the rattle and second, should i be adding some adhesive foam weather stripping? What have you done and have you had the same rattle?
My rattles bad too. Annoying, need to add something to mine as well.
Weatherstripping or flat moulding. There's plenty of room for even 1/4 strips of rubber to be glued to the roof itself.
Screws definitely won't stop the rattle.
Yep mine rattles too
Weather stripping at a local hardware store works for me, $3 invested no rattles even with my 10" sub on.
Gonna have to invest in the some
I put the seal kit on mine. Well worth it really tightens it up.
I used the clips and screws on mine because I trailer it some running 70 mph on interstate roof stays put and no rattles or squeaks either.
Well, I had the sport roof installed, and had the rattle, or squeak. After looking over the forums, I decided to try the bending of the tab on the pillar post. It was only squeaking on the drivers side. I took a 3/8" extension, put it inside the finger of a glove to protect the paint, and tapped it with a hammer. No more rattle/squeak...
1 - 14 of 14 Posts
