What is that squeal from? Is it the belt? Why does it happen?
Vendor
Assuming you mean say under 10 mph when you let off the gas, that is the primary disengaging and the belt spinning the primary clutch bearing forward faster than the engine is turning. Normal sound.
Mine is a 14 900 crew xp and has done this since new also ...but here lately the "normal" squealing/whining sound has been replaced with a rough metally/growlly sound from time to time then it will go back to the "normal" sound ...What is causing the metally/growlly sound?
Yeah at slow speeds and stops with a little throttle
