1 - 20 of 52 Posts
In trying to remove my front differential plug from my Ranger 900xp I stripped out the socket!!!
Any ideas how to remove it????
I haven't used them but they make torx screw extractors.
Or go get an ez-out. First I'd go get the replacement plug from the dealer so you know how deep you can safely drill the plug. There's a magnet on the back side of the plug you don't want to pop off and have floating around in the diff. Use the largest you can safely get away with.
If you're referring to the drain and/or fill plugs, they are Allen, not Torx. The use a 6mm Allen tool of your liking. Another way to get them out is put a short bolt into the stripped hole and weld it together then just unscrew it like a normal bolt.
Mine are 8mm allen on the 1000 not sure about the 900.
I was thinking they were allen too.
Discussion Starter #8
Thanks all, but regardless the socket is completely stripped out. i have to remove the plug. i have a new one/
Give us a Pic if you don't mind. Have to go advanced for it to post correctly. Ez out is the way I would go, but some here are much more experienced than I. Might want to check out page 3 on my secondary clutch thread. Pyro is a machinist and has mucho experience.
Let's be accurate here. I am not a machinist. I am a hobby machinist that has never had any formal education in machining. My machine shop education comes from lots of study of books and hand on school of hard knocks experience. I consider myself fairly knowledgeable in the field of machining and mechanics, but a true machinist, someone that makes their living in that field, is far more knowledgeable that I am. If you want to see some real machinists watch some Youtube videos by Keith Fenner, Abom79, This Old Tony, Keith Rucker, mrpete222 or some of the others there. I am a regular follower of the channels mentioned above.
I've been under a 500, 700, 900 last Thursday and today a 1000. All were 8 mm allen
Doesnt mean that maybe a non oem plug got used previously.
I stand corrected on the Allen size. 6 mm for the engine oil drain plug and 8 mm Allen on differentials and transmission. I have many come in to my shop with stripped holes. A lot of folks doing their own oil changes don't have metric Allen or don't know that the plugs are metric and will use an Imperial Allen. Doesn't work so well.
Used 5/16 on trans the first time. After allen got stuck in plug, went to an 8. Considering you have a centered hole, the ez out should do the trick. straight or spiral, I'm guessing straight.
And Steve, you should have been a machinist. You sure have a great detailed library in that head!
Thank you for the compliment. I'm happy about almost every occupation I've ever had but being a firefighter was my forte'. I would not have liked to be a mechanic or a machinist for a living, working at them to survive would have taken the fun out of it. I find both enjoyable becasue I am interested in both and becasue I don't have the stress of depending upon them for a livelihood.
I have a '15 900 XP both are 8mm, engine is 6mm You will need an extractor, no doubt!
Food for thought: One thing I learned a long time ago is always check the fill plugs FIRST.
If you can't get that one off and have already drained your housing / engine / transmission you are 100% pooched!
Same was suggested when I tore into my Xterra. Sure enough the rear diff was badly stuck. Iron plug so stuck it with welder. Used a bit of teflon tape to prevent the issue again
Discussion Starter #16
Thanks everyone for your comments.
FYI I have the mechanics manual for the rig and it says it is a torx socket.
I did the engine oil with the torx and the front diff fill with no problem .
The drain plug was way to torked in.
Looks like I will have to drill into the plug short of the magnet as recommended and use an easy out.
If this does not work I am screwed.
What year is the rig? Post a picture as another suggested please. I may have a couple other suggestions. I've worked on alot of farm equipment and if it wasn't stuck it was probably because it was broke
Is Polaris getting so cheap they had someone from China do the manual or simple layman not an engineer and the translation got fouled? I've seen similar problems on other things
If your still working on getting it out, try rapping right on the head of the plug with a brass punch and a hammer. Have someone hold your purse if you know what I mean. Or carefully give it a few raps with an air hammer. I don't remember what style of plug it is used on these but I have used this trick countless times on o-ring boss plugs on tractor undercarriages. 3/16 allen head and farmers turn them in until the head strips out. Many times after hitting it with a hammer you don't even need the ratchet you can just spin the socket with your fingers. These plugs may not the ordinary o-ring boss but I figure it's worth a shot.
Many times the judicious application of heat can make a huge difference between difficult, destructive removal and successful removal. The difference in coefficient of expansion between the steel plug and the surrounding aluminum is quite large. Warming the aluminum case will expand the threaded hole more than the steel plug expands resulting in a looser fit and easier removal.
1 - 20 of 52 Posts
About this Discussion
15 Participants
pyromedic
PRC Polaris Ranger Club
Full Forum Listing
