How does the swaybar affect load hauling? Do you mean it will be less stable? If so, I would agree.You will dramatically reduce your load hauling ability...something to keep in mind if you ever carry any weight in the bed...
That's probably true, but with the loads that most people carry on a regular basis it's barely noticeable.You will dramatically reduce your load hauling ability...something to keep in mind if you ever carry any weight in the bed...
You will need to remove the bar and the end links (no quick disconnects available that I am aware of), if not it could get bound up on the shocks and rear A arms in the forward position or the A arms in the down position and do some damage to the unit.Is it totally removed or just disconnected?
Please explain your statement.I run limit straps with a 3" lift and no sway bar and my machince is far more stabile than is was in stock form with the sway bar in place.
You have some nice aftermarket pieces that make up your suspension, so there are some different variables that come into play, one being the linear spring rate on your Elkas and the adjustable dampening and rebound.
I think the OP is looking for info closely related to a stock machine.
...Removeing the sway bar does not effect load carrying capacity...
Without a lift, the shock will limit the downward travel. When you add a lift, that increases the max CV angle. You "should" be pretty safe (as far as CV angles go) to remove the swaybar as long as you don't have a lift.......If down travel was that much of a concern to Polaris I would imagine my 6x6 would have an additional swaybar on the rear most axle to prevent too much down travel........
