I've finally put my NEW ranger in the shop. It's 4 months old and has a lot of problems.
I'll describe the problems here and we'll see how close people can guess the causes. I'll post the results when I get it back from the dealer.
Specs: 2006, 500 carb, 4x4, 77 hours.
1. carb runs really rich at idle, can't stay within 10 feet of the exhaust because it stinks so badly
<font color="purple">fixed</font id="purple">
2. when hot, idle will drop from 1200 to 850 for 5-10 seconds every few minutes.
3. cranks fine when cold with no choke, but I have to apply throttle for it to crank when hot.
<font color="purple">fixed, although it doesn't start for about 2-3 seconds</font id="purple">
4. backfires when coasting down from a high speed road run
<font color="blue">problem has cropped back up again</font id="blue">
5. 4wd engages at will, particularly when in reverse
6. 4wd won't disengage when engaged normally
7. valve cover gasket leaks oil
<font color="purple">replaced</font id="purple">
8. something's binding in the drivetrain. it forces the front wheels straight ahead. turning is EXTREMELY difficult. If I slam on brakes when in reverse, the "problem" will release for a while.
<font color="purple">"fixed" sort of. The front brakes are hanging. If I tap them as I drive it will release and work correctly.</font id="purple">
I turned it in this part Thursday. They hope to begin looking at it a week from Friday, 8 days away.
Let the speculation begin...
Should I also mention that they are considering it for a possible trade-in on a different brand utv?
