Time for a new crank??
3.9K views 9 replies 5 participants last post by  Toxic-21
After tearing into my case on my 2017 570 crew I noticed the lobes of the crankshaft appeared to be hitting something internally which ground down a flat spot on both of them. I believe the bearing gave out as there is a serious amount of play in the rod. Looks like the timing chain ground a groove in the little ear of the case as well...does this mean replacing that case half??
I would be contacting nFlow and talking to them about an overhaul.
Reactions: fswan
#7 ·
I believe it’s designed that way.
As far as the discoloration ( heat marks) on the crank, that is normal as well.
From Polaris the crank and rod assembly is not Serviceable, it comes as an assembly.
The 2 piece crank is heated to expand the metal and the Rod / journal assembly is pressed together.
I have no idea about your mechanical ability or the tools you have at your disposal, but just looking at this you may want to consult a professional.
There appears to be several specialty tools that you may need.
#8 ·
Thanks for the input Toxic. You are correct in that the crank counterweights are designed that way to balance them. I just ran up to my local Polaris dealer and had then press the crank out for me for about $12. I’m fairly mechanically inclined and know I can rebuild this little single cylinder motor but it’s my first ever and will probably take me a little longer as there will be a learning curve there. I also had the shop look over some other parts for me to help guide me on my way.
