1 - 20 of 20 Posts
I have a 2014 crew 900 and want to know what size tire and rim I can put on the bike. I don't have a lift on the bike and don't have plans to put one on. What are some tires you can recommend? I ride in mud and sand. Thanks all.
27 inch tires fit great. I have Blackwaters and like them but you will find a lot here like Roctanes and Moto MTCs.
Yes on the 27s on 14s and no rub stock setup
I also run the black water evolutions and love them. I got a small 2" lift and 30" tires and love it
Post a picture of what the crew looks like with the 30" tires and lift
I have the 27x10x14 EFX Motoclaw's on all 4 corners and have had really good luck with them this hunting season. I have 400 miles on them in the rocks and mud (since we've had a bunch of rain) outside Brackettville, TX. Tires still look like new.
I have a friend that is running the 27" MotoClaw with 14" wheels on his crew and has no problems with rubbing. He's not much of a mud guy and will say those tires aren't holding up well at all on the hard stuff. You would probably be safe running 26" MTCs or a little bigger bighorn without a lift. 28 MTCs rubbed bad on my old crew without a lift..(his claws are right at a year old and he has around 1500 miles in them)
So the 30" tires and 2" lift kit work well? No need to change A-Arms
Yeah 28s with a 2 inch kit is pushing it. I have 28s and a 2 inch lift and they fit fine but they run small and actually only measure about 27.5 inches tall.
Anyone using these 2.5" lift kits?
POLARIS RANGER Lift Kits
Do I need new arms with this 2.5" lift kit?
How big of tire can I put on with this kit before needing forward arms?
Ranger.jpg This is my 2014 800 Full Size. I have a Marshall Motoart 2.5" lift and 28" Zillas on 14x7 M12s. Got about 200 miles on them now and I still love the set up.
So I have the stock tires and rims 26x9-12 & 26X11-12.
I have the Marshall Motoart 2.5 Lift that I will be installing.
Can I run a 28X10-12 all around on stock rims?
Or do I need a 28X9-12 on front and 28X11-12 on rear?
I want to stay with stock rims, just not sure about tire width 9"-10"-11"
Wow; I am researching the same thing today.
I have the Marshall 2.5 in. Lift 28x10x14 all around. I rub a little in full turn when compressed. Handles good definitely got better ground clearance now.
1 - 20 of 20 Posts
