1 - 3 of 3 Posts
Anyone have experiences with Journey 350 tires?
What is difference in Bighorns and Bighorn 2?
What size tire do you recommend on standard 12" steel wheels? Some trail riding, mostly work, want a bigger tire that 25" stock tires. I am thinking 27x9x12 and 27x12x12.
Never heard of the Journey 350.
The Bighorn 2.0 is a (only slightly) lighter version of the original Bighorn.....good for quads, but not really geared toward a SXS.......I'd stick with the original.
I'd also stick with 12" wheels......less prone to pinch flats in this rocky terrain, and provide a slightly smoother ride (more sidewall equals more cushion).
A true 27" tire is going to be VERY close to rubbing. It might only rub during suspension travel and full turn, but it will probably rub slightly. A 27" Bighorn measures a hair over 28" at 14 psi, so you don't want to run those without forward A-arms. If you want to guarantee absolutely no rubbing under any condition, better stick with a tire with an actual size of less than 27".
1 - 3 of 3 Posts
