Does anyone know the torque specs on the front diff bolts on a 800 ranger?
Southark · Registered Joined Mar 26, 2014 · 39 Posts Discussion Starter • #1 • Dec 9, 2014 Does anyone know the torque specs on the front diff bolts on a 800 ranger?
pondskum · Registered Joined Sep 23, 2013 · 533 Posts #2 • Dec 9, 2014 7-11 ft/lbs. for the cover bolts.
pondskum · Registered Joined Sep 23, 2013 · 533 Posts #3 • Dec 9, 2014 8-10 ft/lbs for fill and drain plugs
Southark · Registered Joined Mar 26, 2014 · 39 Posts Discussion Starter • #4 • Dec 9, 2014 Would you happen to know the ones that bolt it to the frame?
commanderjjones · Registered Joined Dec 29, 2006 · 22,346 Posts #5 • Dec 10, 2014 Southark said: Would you happen to know the ones that bolt it to the frame? Click to expand... Don't have a manual handy, but those would probably be around 50 to 60 ft lbs.
fswan · Premium Member Joined Nov 19, 2010 · 6,359 Posts #6 • Dec 10, 2014 Southark said: Would you happen to know the ones that bolt it to the frame? Click to expand... 40 ft. lbs. on an '11 800.
pondskum · Registered Joined Sep 23, 2013 · 533 Posts #7 • Dec 10, 2014 fswan said: 40 ft. lbs. on an '11 800. View attachment 7772 Click to expand... What he said... ---^
M Markm1960 · Registered Joined May 19, 2019 · 5 Posts #8 • Jan 7, 2020 fswan said: 40 ft. lbs. on an '11 800. View attachment 7772 Click to expand... Thank You !
