1 - 15 of 15 Posts
I did spring for front and back glass on my new 570. So far no wipers or doors.
I have used Rain X off and on over the years, and I like it.
I decided to give it a try on the UTV Glass. My glass was pretty clean, however I still cleaned it inside and out with some Great Spray Glass Cleaner I got from the Windshield replacement shop, using Blue Paper Shop Towels.
Per the Instructions I then wet another clean Blue Towel with Rain X Treatment and rubbed it in in a circular motion. I rewet the towel as required.
I then let it set to dry and form a haze.
The instructions said you could buff out dry or wet. Dry looked like it was going to take a while. I got a spray bottle with water and misted the glass, then buffed it out with clean towels. NOTE: Distilled Water in the hand sprayer for the final buffing would probably be even better. I have really hard water, Great to Drink, but lots of calcium.
I figure the Rain X treatment should last for about 3 months. The small bottle should do a years worth of treatments on the UTV.
I figure about every 3 months I will need to do a good job cleaning the windshield anyway to keep it clear.
I do see a down side to using it. The wife will want me to start cleaning the glass and treating her Dodge Truck.
Now I will need to wait on a rain to see just how well it works.
Bob
An excellent idea for glass windshields!! But if any of you have poly or acrylic windshields, don't use Rain-ex, it'll mess 'em up bad!
Reactions: mustangwagz
Ditto. I've seen that multiple times.
Guilty .......
What's the best treatment to keep poly windows from fogging up?
Honestly, im not sure personally, but ive found that a small fan works GREAT at keeping mine unfogged. Now, granted, my cab is heated for winter use, however irregardless of weather if it starts to fog, i turn the fan on and bingo..problemo solved!
I use good quality car wax on my poly/Lexan windshield and it works great. It removes vitually all the light stratches too.
As mentioned above, car wax works pretty well. Novus or other plastic polishes are probably best (but a little expensive). Furniture polish works too, but you have to put a little more elbow grease into the polishing portion in order to keep it from streaking.
I just got my first Ranger ETX. Dealer suggested I use Rain X on the glass windows - used regular product on the outside the anti-fog product Rain X product for inside. So far it works great and a whole lot cheaper than a windshield wiper!
In regards to poly, Plexus is good stuff
Vendor
I've been thinking about putting Rain-X on my glass windshield too. Did you do both sides?
I would on a SXS, since both sides have a chance of getting wet. On my car and truck, I only treat the outside.
when I do the rain x treatment on my autos, I apply as directed, wait till it dries or hazes and take off with an auto buffer with a new bonnet work great, I usually do 2 or 3 treatments in a row seems to last longer
1 - 15 of 15 Posts
