Let the local repair shop source the parts.Is there anything else I would need to purchase with the bearing if I find a local repair shop?
Yes....... if the dogs are not gone and the spring is in place ...........it always works. What lubricant are you spraying in there ?That is correct, the cable slid smoothly but once reattached to the lever (#26) it was not smooth. That lever sits supper close with no room in between to try and lube the shaft. Is it just having to continue spraying it and moving back and forth trying to get the lubricant to work it's way to the shaft?
