Stink, on a 2009 700 I prefer to remove the front bumper and after disconnecting the power and pulling the axles out and then unbolting the gearcase , pull the gearcase and shaft out all in one piece through the front and then knock the roll pin out on the ground in front of me. Then go back in with a 2" long stainless steel bolt ...5/16" ...diameter and a self locking nut instead of the roll pin. Try to lube up the slip yoke on the transmission if it is stuck on there. If it hasnt been greased in a long while , the slip yoke tends to freeze on the shaft. See if the slip yoke will take some grease before removing the shaft . Use Never Seze on everything with splines....Always ..
