I agree. Just like oil changes....the brand doesn't matter nearly as much as just doing it regularly.I don't think the type of grease matters as much as making sure it gets greased.......
Thanks guys. For the life of me I hadn't been able to figure out why a "Premium U Joint Lube" (other than increased revenues for Polaris). Calling it a U joint lube is a bit of a misnomer when the grease isn't anywhere near the U joints.
I remember when greasing the truck slip joints (which were drilled down the centre from the yolk end), you pumped grease until any water was pushed out & grease started to emerge.
On a side note, are there replacement U joints that are greasable for the Ranger or RZR?
Agreed. That's why I switched all my greases over from running John Deere grease to Amsoil grease. Night and day difference.The brand does matter. There are lots of greases out there that are cheaply made and do not last.
Kris, Are you talking about the O-ring that is at the end of the slip joint ?Oh I just thought about Polaris's statement about only 3 pumps of grease in the slip joint is that more to prevent making a mess as opposed to not blowing a seal out (which isn't there)?
Is there one? :dispirited: I was just wondering why they'd only want 3 pumps of grease. I know if you go "nuts" pumping grease into Bearing Buddys that you can blow out the seal & get grease all over the place.Kris, Are you talking about the O-ring that is at the end of the slip joint ?
A O-ring that sorta kinda retains the grease should be there....Is there one? :dispirited: I was just wondering why they'd only want 3 pumps of grease. I know if you go "nuts" pumping grease into Bearing Buddys that you can blow out the seal & get grease all over the place.
[h=2]O RING-.875ID X .125 DIA[/h] [Built 2/22/11 and After]I'll check that next week (on the road in TN right now). Gassed up @ the Pilot on I-75 near Pioneer & saw the billboards for Royal Blue. Also another ORV park had billboards, something about 7,200 acres to ride in?
I bet that area is fun to ride in.
I bought mine around that time, so I'm thinking mine probably doesn't have it.
If you add together all of the land encompassed by North Cumberland WMA (Royal Blue), Brimstone, and Windrock (all of those trail systems are adjoined), there's WAY more than 7200 acres........more like 300,000 acres.I'll check that next week (on the road in TN right now). Gassed up @ the Pilot on I-75 near Pioneer & saw the billboards for Royal Blue. Also another ORV park had billboards, something about 7,200 acres to ride in?
