I just ran into an issue that I had not seen on any previous threads. I purchased the SuperATV forward a-arms and a Marshall Motart 2.5" lift and after trying to install the two components realized that the lift brackets do not work with the a-arms since the a-arms do not have the threaded hole for the screw on the lift bracket that prevents the lift from pivoting on the shock attachment as the stock Polaris a-arms do.
Anyone have any suggestions or have they run into this as well? Only solution I see is to now look for a top shock mount lift bracket. Anyone else run into this
