I'm putting a Warn 2500 ProAdvantage winch on my '12 800EP and would like to use the OTTW switch instead of the factory switch. The pins for upper and lower lights I understand. Now this is were I need your alls help.
Pin 1 and 3 are labeled OUTGOING, pin 2 is labeled INCOMING. There are 2 wires coming from contractor, one green and one black that go to factory switch which I can use but again I would like to use the OTRATTW switch which would match the other OTRATTW switches I already have installed.
I talked to Jim at OTRATTW and he suggested I ask you guys how you wired it???
Thanks.
Thanks.
