Looks like my water pump is leaking, I'm assuming it is coming from the weep hole as the hoses look dry. Should I replace the whole pump assembly or can I get by with tear down and replace the seals?
Probably get away with just seals, i dont know about the 900 but seals were a pretty easy fix on my old 700...
Super Moderator
You can probably get by with just replacing the seals.
If you price all the parts except the housing is is only like $50. If the shaft is worn or the shims (spacers) are worn, the new mechanical seal won't last long.
I just replaced the whole pump... twice now :-(
