Sorry but just don't see how the Duraclutch helps for larger tires besides belt life. There has to be a ton of power lost down low unless you can change the sorting if its a "one size fits all" kit. Clutch kits have the ability to change the engagement RPM so the engine is more in its powerband when things need to start moving and helps it shift out faster to keep it in its power band, gives the machine a great mechanical advantage. That's why when guys install clutch kits the first thing they notice is how much faster their machines are off the line and in the midrange.
Please help us understand how you have developed your opinion about clutches and why you give the advise you give...
What is your experience with a Duraclutch?
What is your experience with any clutch like a Duraclutch?
What is your experience with anything other than QSC?
It is good to hear you are happy with the QSC, and I'm sure many others will benefit from your testament, however, your bashing of other clutch options isn't helping the guys who are looking for information..in fact, a lot of what you're saying is laughable and simply not the case...
There is a lot of ways to skin a cat, and there is rarely a 'best' choice, only what works best for someone...and that is expressly true with clutching...you can't offer sound advice on clutching a machine unless you know how it will be driven (speed, terrain, payload, etc...) so coming out of the gate stating that your setup is the best choice is beyond comical...
Just because you don't 'see' it or understand it doesn't mean it doesn't work...
... There has to be a ton of power lost down low unless you can change the sorting if its a "one size fits all" kit.
Obviously you know just enough about clutching to confuse yourself...
I'll say it again....you know just enough about clutching to confuse yourself...
I'll say it again...you know just enough about clutching to confuse yourself...
bottom line is if you think a $209 set of weights/spring for the primary is even in the same ball park in performance/improvement as a setup like the Duraclutch then you truly are confused...
you get what you pay for...
If you want to spend $200 for a different primary spring/weights, great.... that will deliver an improvement...the spring/weights can be tailored to your taste
If you want more improvement, spend the money on a better secondary, the stock one is junk...the spring/helix can be tailored to your taste (I happened to like the DDP setup but I'm sure there are many others that perform well...)
If you want a work horse clutch get something like the Duraclutch...
