1 - 3 of 3 Posts
I have stock rims right now and the tires are 25-10-12 in front and 25-11-12 in the rear. I'm looking at putting 26-11-12 EFX Motoclaws all the way around on STI HD3 wheels. Will the front tires now be an inch wider than the rears or because they're the same wheels it will be the same and the extra inch goes inward and not outward? I'm trying to figure out if I would need an inch spacer on the rear to even it out.
Most aftermarket wheels will space them out a little to compensate for bigger tires. Just need to look at the specs for the wheels you are buying and make sure you get the right offset.
Well my tires are on and they make my Ranger wider but there is no need for spacers. Just in case anyone else had the same question.
1 - 3 of 3 Posts
