Does anyone know if a Wheel Spacer from a Ranger 800 will fit on a Ranger 900?
I realize studs are different sizes but, I figure if the spacer fit over the larger studs on the hub then I could bolt the spacer to the hub with a 12mm nut then I could install a set of 800 Ranger rims on my 900 because it would have the same studs.
I have ordered a set of spline lug nuts in case I have to mount the 800 rims on the 12mm studs.
Thanks, Shane
· Premium Member
A spacer made for an 800 will (probably) have 3/8" holes (9.525mm) so they would have to be drilled out to 12mm.
· Administrator
Thanks, Shane
Just curious, what 800 rims are you referring to. Are these new, used?
