1 - 12 of 12 Posts
I'm no where near my manuals and my cousins 900 has no power.
Codes are:
05202 76
2
and
2520 198
4
and
1 51
4
· Premium Member
First 2 are newer than my '11 chart. 51/4 is TPS voltage too low. My SWAG on the 520276 is probably IAC related (520270 on my chart is IAC). Closest code to the 520198 that I have is 520207 which is AWD control circuit. All the 52022X codes are EPS... I know, not much help--hope someone with more current codes chimes in!
Edit: Forgot I had a '13 RZR 900 manual but it doesn't list the other two codes either. :(
Yea I have the same issue. We have the 800'codes here on PRC but not the 900 codes. We need to fix that.
· Administrator
1 51 4 is the throttle position sensor 1, voltage too low.
2 520198 4 is the throttle position sensor 2, voltage too low,
0 520276 2 is the throttle position sensor ( 1 or 2 indeterminable) position sensor correlation fault.
Your first LARGE number represents the total number of trouble codes present.
Greg, thank you for that! I'm guessing he either has a broken wire or a low battery.
· Administrator
Curt, your welcome, thanks for all that you do on this Forum
As you already know, start with the simple stuff first. I would suspect a bad battery, have it load tested.
I'm having this same issue with my 2015 Ranger 900. Turn the key and nothing happens: no lights, no relays clicking; it's dead. The battery is fine. The battery has a resting voltage of 12.9V. My accessories, which are wired separately from the the Ranger, all work normally. The Ranger, however, was dead.
Now, it seems to have healed itself. I am showing the same codes as the OP on my cluster.
Discussion Starter · #8 ·
It turned out my cousins Ranger had a loose TPS. His would turn over and start it just didn't have power.
ChrisH have you checked the plugs on the back of the ignition switch?
Discussion Starter · #10 ·
It's doing it again. I thought I had a manual for this model but I don't. Is the TPS inside the throttle body? I don't see it? Also we pulled the TBAP and it was wet with gas. I can't understand how that happened when it is before the injectors. This is a little strange. I guess I need to buy a manual for this model. :suspicion:
1 - 12 of 12 Posts
