1 - 11 of 11 Posts
I put 27x11x14 tires on with 14x7 wheels and 2 inch wheel spacers all the way around on my ranger 900xp. They rub when I turn and am wanting to know if a 2" high lifter lift should make the rubbing go away. I currently have the shocks on the outer mounts and the springs as stiff as they will go.
I am hoping this will work and also be able to back the springs off to a softer setting. Thanks.
Or save your money and take the wheel spacers off
Reactions: Expat
Discussion Starter · #6 ·
I am pretty sure the spacers are most of my problem, but I want them on there for driving down rows in my fields. Makes it a lot easier. I just ordered the 2 inch lift kit that basically just moves the shock mounts. I took some air pressure out of my tires and that helped quite a bit so I shouldn't need much to get rid of my issue.
I've never run spacers. I have the same bike with a more aggressive mud tire and can only imagine how muddy you get. I personally like how my tires stay tucked in the wheel wells But I can understand why you have them.
Reactions: Rjbrooks
1 - 11 of 11 Posts
