I have a 2020 Polaris winch that will not allow the rope to go out. I can hear the clicking when I attempt to let the rope out. It was working fine until I raised my plow a bit too high. Any advise ?
Flip it to free spool and see if you can pull a little line out to make sure spool isnt stuck.
Also check your fuses and/or circuit breaker resets. You should have one or other as one may have tripped if ya put it in a bind.
Auto winch stop?
‘17 Ranger 570 Midsize
Make sure it is on free spool hook to something immovable with chain etc and back up. It's probably just too tight or tightened backwards. Once you pull out a reasonable amount use the opportunity to use the winch to put the line on tight.
Oh, it's a normal thing for plowing as far as I know. At least, I go the wrong way every once in a while.
