Anyone know what the power usage (amps) is from the Polaris wiper kit ? Mine is hooked up to the power bar (or whatever it's called) next to the winch electrical stuff. I looked in the owners manual & it says the accessories have a 20 amp fuse..............I am assuming the wiper kit must be tied into this fuse...............I am asking as I purchased a small heater (8 amps ) which has the cigarette adapter..............since the ranger has 2 adapters (I assume these are also tied to the accessory fuse)one above the other, could I technically run 2 8 amp heaters if needed (one on each side of the window) & be ok, but if I needed the wiper on I would have to pull one heater out to prevent blowing a fuse or could I have all 3 things working & be ok ? Thanks....................cheers
