1 - 8 of 8 Posts
I have a 2007 700 ranger. one day I was spraying weeds in the hays field and it just died and had no fire. towed it to the house and replaced the main fuse (blown). started right up until I put it in gear, boom fuse blown. I repeated this with the same results. Any Idea's
Errrrr, you have a short :)..... I would check the battery cables, especially the one to the starter for chafing on the engine.......
thank you I will. but why wouldn't it do it when it starts if there is a short instead of waiting till I put it in gear?
Ahhhhhhhhhhh....but the question should be............why does it short when you put it in gear ????? o_Oo_Oo_O
Reactions: Rooster59
I'm down with that, any thoughts? some of the terrain is rough underbrush that I went through but there isn't, aren't any wires underneath. is the shifting linkage external and maybe getting pinched while in gear?
rd, nothing about being in gear would blow the fuse. Vibration or movement may be causing the intermittent short. Make sure the ECU is plugged in properly .
Maybe should have went organic instead of using Ranger Pro and killed his ride:)
1 - 8 of 8 Posts
