Yet another home made Lock n' Ride plug
97345 Views 70 Replies 50 Participants Last post by  mx1alex
Here's my version of the Lock n' Ride plug. I wanted someting that also had a hook on top so I would have additional tie-down points higher up in the bed.
Here are the individual pieces. The key components are 2 1-1/2" test plugs (I bought mine at McMaster Carr for $1.50 each). The rubber from the test plug needs to be ground down a little for proper fit (chuck in drill and run over sand paper). The eye hooks are 3/8" and I bought the longest I could find that were threaded all the way to the top (they measure 5" total length). I used a 2-1/2" piece of all thread and a 3/8" nut to connect the eye hook and the all thread to get the right length. The spacer is 3/4" sch 40 PVC. The other hardware items were parts of the test plug, plus 2 extra 3/8" nuts.
Here's the test plug
To expand the plug you hold the eye hook and tighten the wing nut...works great...a little over $4 to make.
Reactions: 5
1 - 20 of 71 Posts
I LIKT EM!!!! I just picked up 4 of the test plugs today at Home Depot for $2.47 each. I was gonna use them like they are but I like your idea ALOT better!!! Thanks for the info and pictures............:)
What a deal! You did a very nice job on those things. Great write-up and pictures to boot. Boy ya can't beat that. I may have to look into making a few of those things. It sure beats the heck out of the $17.00 ones that Polaris sells. Thanks for sharing the info!
17.00 The last ones I bought cost 20.00
Great idea...
That is a good idea.
engineering at its finest...
Ordered 8 plugs from McMaster-Carr P/N 2613 K21 online and recieved them in 1 day. 5.25 ups and no tax. Put them in the drill press and sanded with a sandpaper block. Now I am ready to make my own guncase holder mount. Thanks for the Info.
I think this is brilliant. Gonna try to bump it to the top. Great idea!
They work great, I have been useing mine just like that for 2 years now and only lost one. [:0] 100 lb. dog was snaped to it and dog jumped out of bed to chase a deer, got dog back no plug! [:(] If you make them long as you can they hold better. [:D] You also may need to sand rubber a litte to let it go in easy.[8D]
Take a good look at the lock-n-ride holes the top half is about 1/4 inch larger dimeter than the bottom half if you want to go way deep with them. I end up using a rubber mallet to put two mine in most of the way.[:D]
Joe in Tucson
ok... I got all the goods to make a few of these but the eye bolts I got were longer and did not thread all the way to the top...ya think they will still work if I put some sort of spacer on top of eye bolt?
Run a nut all the way up and jam it where the threads end. Tighten by turning the eyebolt. The nut on the bottom might have to be epoxied to keep from spinning or use a T-nut like I do:
http://www.prcforum.com/topic.asp?TOPIC_ID=3877
Thanks for the suggestion Mark. Took me a while to find the same parts but once I did, at my local hardware, it took me all of about 2 mins to put two together and install them. Worked great keeping the cooler in place riding on Saturday helping put the snowmobile trail in over here in SW Michigan.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by rowdy
Hey Rowdy,
I saw some folks setting up signs this weekend out by Chicora. Was that you?
No we were down by Sister Lakes (Dowagiac) area. I'm sore as hell today from pounding about frickin' 150 1 1/2" square oak stakes 6' long. Didn't feel it yesterday but definitely today.
My south club maintains the trail from Lawton to almost Niles. I'm also a member of the Gobles club and ride most of the time at my house on Bear Lake near Kalkaska.
Sure beats the 20 plus bucks you have to paid the stealer for one.
How exactly were you grinding down the rubber off the test plug?
1 - 20 of 71 Posts
