Being Prepared for a Flat Tire
6.3K views 27 replies 18 participants last post by  Dirty Dawg Dale
Hello
I've owned my 2008 Ranger 500 4x4 for about 3 weeks now and I'm having some good fun! As I'm going out in the woods I'm realizing that I have to start getting prepared for bad luck and mechanical failure.
Short of carrying a spare tire what do you guys carry in case of a flat? I got a can of flat fixer tonight and my dealer recommended a patch kit that has small co2 cartridges to blow the tire up after you put a plug in it. I think I'll get it. I also saw at Tractor Supply some bottles of Slime a type of green gough that you put in your tires prior to getting a flat. Does anyone use stuff like that?
Bruce
#3 ·
I carry tire plugs, a 12v air compressor, and sometimes a spare. I also carry a spare belt, tools to remove the PVT cover, a jack, tow strap, and other 'stuff.'
#4 ·
Hello
Does the slime effect tire balance or have any drawbacks?
Bruce
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Arkansas Rock Rider
I carry a air pump 12 volt and tire plugs. The Slime is a must here for thorns and sharp rocks.[:(]
#7 ·
Originally posted by hsgsports
Hello
Bruce
Balance not affected below 50 mph. Draw backs, 1 the tire guys hate it, they don't like to clean it out when they change tires.
#9 ·
If it's the small CO2 cartidges like you'd use in a BB gun, they work great for motorcycle tires but you have to use a BUNCH of them in order to air up something as big as a tire on the Ranger or a quad (I've tried it). I still recommend a compressor.
#12 ·
I have slime in all of my tires, and handling is not an issue. The stuff is very cheap and works extremely well. A small compressor shouldnt be more than $20. As a side note, getting a flat is one thing, but you can also pop a tire off the bead without trying all that hard. It happened to us on the way down from crown king. The compressor was more than strong enough, but a ratcheting tie down was the real key. You put it around the tire(just like the treads), and as you tighten the strap, it pushes down on the middle and forces the sidewalls towards the wheel allowing the compressor to start filling the tire. This then pops it back on the bead. A tie down is very inexpensive and takes up very little room. We would have been up a creek without it.
#14 ·
Chris, I too have had tire problems on that Crown King run. About three years ago coming back from Crown King late in the day around the old Oro Bell Mine I slashed a side wall on my 700 Sportsman ATV rear tire. Had we not had a bunch of plugs, small air compressor and radial patches It would have been a long nignt. We were at least 20 miles away from the staging area where we were parked. You can never have too much stuff can you. We did what you did with the rachet tie down strap to get the tire back on the bead. Worked like a charm!
#17 ·
Kevin, Yes, right on! I had forgotten to add the valve stem to the list. I have knocked one off in the field. Make sure you buy the very short OEM type stem. If they stick out too far you will knock them off real easy. Moreover, careful as you air up the tire as you can damage one by putting too much side pressue on them.
#20 ·
Eric, That stuff is only meant to be a quick fix and one is expected to take care of it when he gets back to home or shop. I would dismount the tire and clean things up and fix the leak in question with a good patch! In the future slime works much better especailly with such low pressure requirements. I have even used that stuff on my Skid Steer Loader tires that hold 45 psi and it is amazing. More importantly, the clean up is not all that bad either. A good hose rinse pretty much takes care of it.
#23 ·
Hi Bruce,
Although I have only had my 700 XP for three weeks we have been going out with friends in their UTV's for over a year now and have run into all sorts of challenges. I have put together some items we have used to carry in my rig.
In my storage compartment I have a fire extinguisher, scissor jack and 4x4 block to set it on for more lift, a good first aid kit, a tool kit and some rags. This still leaves room for a couple of jackets for the cool fall weather.
In a foot locker style trunk I carry a small shovel, straps, gloves, tow rope, winch kit with tree straps, snatch block and shackles, tarp, rope, work light, extra first aid kit and fire extinguisher, slime and compressor, a good tire plug kit, TP, baby wipes, and two pairs of insulated coveralls. There is also a box with some survival items such as fire starter, water purification tablets, etc.
I know this may sound like a lot but we have needed all of these things at one time or another. It all packs into the trunk with room to spare.
#26 ·
I carry a spare.
