New Guy looking for winch input!!
833 views 6 replies 4 participants last post by  TeamFASMotorsports
I recently purchased a 2016 ranger 900 eps crew and will be doing trail riding and light mudding and was wondering if the Viper Max 4000 winch would be enough.. I don't plan to need it but would like to see if the 4000lb is enough insurance just incase I do need it!! Thanks for any input!
I think that's plenty but others on here will recommend 4500 or 5000. If you're so stuck that 4000 pounder with a snatch block (total 8000 lbs) won't get you out, you should probably be looking for someone with a big tractor!
#3 ·
Rating are deceiving 4000lbs means winch will pull 400olbs on level ground with the minimum amount of cable on the drum. As more wraps go on drum rating drops. I recommend 4500lbs minimum winch with synthetic rope and steel drum as their have been aluminum drum failures. Also you should have a snatch block and a tree saver strap and maybe some extra cable.
