Oil Pressure relief valve stuck
59K views 69 replies 10 participants last post by  POS POLARIS
My in-laws have the dreaded 2011 ranger 800xp it had a reman engine in it that ate the cam and lifters. I was able to replace that from the passenger side after removing the the gas tank. No I’m trying to repair mod the oil relief valve but I can’t get it out. I used a step bit and drilled it all the way through the motor mount for easy access now and in the future. I have tapped on it and tried using a magnet. And I have saturated it two nights in a row with WD-40. I have even started it and can’t get it out.
So I’m stuck with thinking about a left handed bit or something like that. I have already ordered a pack of 4 small block Chevy head pins that so many have recommended. But I still have to get this one out.
And obvious question if it was out it would leak oil from there correct? Especially when running??
It will run with out the y-pipe but I’m not sure I want to do that forever. Any help would be appreciated. Only 300 hrs on reman engine. But new cam lifters injectors and plugs from EBay
I don't think you can drill that dowel out, it's awfully hard. The only real luck I've had is with the engine running usually I can get it to pop out. You might try with the engine running use a torch to heat the relief valve area on the case to see if you can get it to expand enough to pop out of there. Do that at your own risk I guess. Maybe try using a punch and tap the dowel downward to see if you can get it loose, not sure it's doing that with engine running is a good idea or not maybe a last resort?. Worst case scenario guys have had to take the engine out to get to the oil pressure relief valve and tap it out from the oil pump side of the crankcase. The small block Chevy dowel pin fix does work, used it on my 2011 and 2012 800 with good success, looks like quite a few have taken that idea and ran with it
#3 ·
Ok thanks should I put the exhaust back on and let it run for more than 2-3 minutes?? 2-3 minutes is the most that I have tried with a little throttle to see if it will come out. I leave my magnet on it while it is running and it seems to have a little oil on it when I pull it out. Is there a chance it’s not in there?
#4 ·
Any work on the oil pressure relief valve I have done on the 800 I take the exhaust off followed by the front crossmember so I can get full access to the oil pressure relief valve. if the plug is out an engine is running, without a valve in place you would have lots of oil blowing out of there, so I am thinking for sure your valve is still in there. I would use a punch and tap on it lightly to see if you can push the valve down to unstick it. Then try to use the engine oil pressure to push it out again. This may take more than one attempt. usually the valve sticking in the open position is what takes out the valve train and rod bearings because it causes low oil pressure. So more than likely the valve is stuck open in the upward position or at least was at some point in the past
#5 ·
The one I did was I removed the spring from the relief valve push the pin down (if Possible) put the bolt back in (with out spring) and had a oil pressure gauge hooked up and ran the bike,
when the oil pressure went sky high turned the bike off removed the plug and pressed down on the pin and did it all over again (about 20 times) and the pin worked its way out.
#7 ·
Hey guys, never have had the pleasure of uncorking one of these mutha's but wouldnt a couple doses of Liquid Wrench help to cut the crap and help break things free. I realize there is some dissimilar metal action going on but it just seems a load of Marvels Mystery Oil and some light tapping would go along way to breaking it loose.
#8 ·
I always tried to use something like that, I actually had the best luck with Lucas synthetic engine oil additive. It's the most slippery stuff I've ever got my hands on. But expensive.
It's the galling that keeps those baby's stuck in there.
if you've got the plug threaded in a little ways with the sping out, I wouldn't be afraid once you start it to give it a quick revv and see if you can spike the oil pressure and blast that sucker free.
At some point if you don't get it , you have to weigh your time against just pulling the engine and taking the crankcase apart to get it out that way.
#9 ·
Oh that sounds horrible I will sell it as is Or trade it for them before I take that engine all the way apart. They have sunk a ton of money in it and I am only doing the minimum to re coup that. Father in law had a stroke do they added power steering. Had it serviced at same time. Engine blew less than 3 hours later. Licensed dealership service claims hours. Engine was the replaced with a refurbished one. And now we have added almost a grand to that turd. I am sure after I get this fixed it will be a decent unit for someone. But they are done with it. Good thing my labor is free.
#12 ·
Ok plug in idling fine. Revved up a few times. Tapped on housing. Pulled plug. Nothing.
Started engine. Let warm up again. Revved up again a few times. Started to get oil!! But magnet back in still at 1.25 depth and tried again. More tapping more oil. More oil even running oil a bit. Shut off and still no luck. Was ready to try again but now it won’t start ?‍♂??
#15 ·
No, But on my 800s if the oil press relief valve got stuck shut it will spike the oil pressure as soon as the ranger starts bring the oil pressure so high that it will pump up the lifters, causing the valves to float and then will kill the engine. Usually waiting a few minutes for the lifters to bleed down the engine will try to re-start.
As soon as that thing tries to fire I would have the pedal down so that the engine can rev and try to spike the oil pressure enough to push that dowel up.
#17 ·
I would say you have started to move it if the lifters a pumping up to much, see if you can push it down again (a little bit of force) and run again till oil pressure goes of the scale pull the plug and push it down again (repeat) don't worry about measurements you will feel it move when you push it, little by little it may came out.
Took me 20 plus goes to free the one i did.
#20 ·
jeep , it is easy to tell when all the valves are open because the engine turns over like it is on steroids .....like it has NO COMPRESSION. I am thinking you have something else going on.. Got spark & fuel ? Fouled plugs ?
Reactions: POS POLARIS
#23 ·
I feel like it has some without putting the tester to it and sitting 30 miles away at work. I agree it always makes you think spark or fuel. But it also seems like a low oil level kind of shutoff but as I know now these engines don’t have such a sensor. So it lottery ran perfect. I shut it off to check dowel. And now it won’t start. It definitely cranks easy. But I feel like there is something compression.
so after I put the cam lifters spark plugs and injectors on. This is how it acted. It never really idled until I took the exhaust off. So then I vacuumed out the exhaust to make sure nothing was blocking it. And started messing with dowel. Ran really smooth until current event. Even with exhaust back on.
