If I floor my RZR the front end lifts up about five inches but the wheels never leave the ground as I slowly back off on the throttle the front end slowly comes down. I have all four shock on the lowest setting trying to cure this but no luck. also as the rzr lifts the steering wheel moves back and forth and the front wheels are toed way in and when I slow down the wheel whips back and forth again until the rzr lowers back down then it drives normal again. I had a friend watch down the street and he says
when the front of the rzr raises up the two front wheels actually go closer together and toe in. the A arms drop all the way down as if you lifted the center of the Rzr with a jack as far as you can without lifting the wheel off.
Scary Situation. any ideas. motor is stock. but somthing in front suspension seem changed.
