There is a code on the bottom of the rod caps but i cant get my phone to read it. So small and maybe scratched. So i had to plastigauge the rod bearings. I went ahead and ordered a green set and a blue set, thinking those were the most sizes used. Mine ended up needing the green bearings so that would put make my rods a 2. But yeah, i got it all back together and running fine. After having a oil leak from the tensioner,that i had to replace the washer on,and i had to figure out why it started right up when i first put the motor in,but when i replaced that washer the next day and then tried to start it,it wouldn't start. I figured out it was out of gas, then i got it started,and then it was missing,then found out that i had a plug broken. The threads broke right off the bottom, of the plug,which i never had happen before. Thankfully i was able to use a small flathead screwdriver to stick down in there and back out the threads. So then I picked up two new plugs the next day and put them in. So now she's running fine and is good to go.
